The Samsung Galaxy Tab 4 8.0 from Verizon (SM-T337V), also known as the Samsung SM-T335, was launched on April 1, 2014. The 8-inch tablet is powered by a 1.2 GHz quad-core processor, has a multi window functionality, and a 3 megapixel camera.
21 Questions View all
Are lcd's compatible between versions of galaxy tab 4 8.0?
Hi i need to know if the lcd's for other editions of the galaxy tab 4 8.0 are compatible with the lte version? I need to replace for a customer and want to provide cheapest possible service and the other models have cheaper lcd replacement options. Thanks in advance!
Add a comment
Chosen Solution
There are for sure different parts for 4G/wifi versions, which is usually a good hint that something is different. Taking a look at them, it appears as though the 4G antenna may be sandwiched in the display assembly.
I would for sure use the correct one.
Score 1
Add a comment
Fraser, if the lcd's are different part #'s, then you can bet there are differences, you would be taking risk in ordering anything but the correct part # for replacement.
Score 1
Add a comment
Add your answer
Fraser Dalgleish will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 85
