A collection of guides and support to help with washer repair.
LG WASHER Direct Drive won't spin
The drums turns in normal wash mode but as soon as the indicator light blinks between wash and spin the drum stops spinning and a strange rumbling noise is heard. We did do the pull plug out for 1 minute/open door 6 times in less than 12 seconds thing. WE have an LG Direct Drive front load washer. Do you know what it might be?
Score 1
2 Comments
Sandra Roberts what model is your LG washer?
by
Direct drive no belts or coupling plastic spline is ok
by
Add a comment
1 Answer
Chosen Solution
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 4
6 Comments:
It’s a direct drive so no transmission. The motor is directly connected to the drum
by
direct drive it has no belt or transmission
by
hahahah they did not help at all. I had the same problem. It will not spin and I have no transmission and no belt because it is direct drive.
by
@shane35741
What is the model number of the washer?
by
Upside down f and then a e I have a direct drive lg
by
Show 1 more comment
Add a comment
Add your answer
Sandra Roberts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 35,655
