Fujifilm FinePix 16.4 megapixel HD waterproof digital camera has the ability to capture up to 10.10fps. Released on 2015.
10 Questions View all
Why won't my camera focus?
My camera worked fine before, but now my images are coming out blurry. I have tried resetting the device and it seemed to not work. How can I get my device to focus again?
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
If you are having issues with image clarity, make sure that the subject is not too far or too close to the camera itself. This may seem like a simple solution but it is often effective. Also check to make sure that nothing is blocking the lens and that it is clean. If these solutions do not work, try using your device in focus lock which can be enabled by depressing the shutter button halfway.
Hope this helps, and good luck!
Score 1
Add a comment
Add your answer
Daniela Pesci will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,630
