Repair information for the gear you use to get out and get active.
My treadmill won't turn
TREADMILL NEW BALANCE
1500 TREADMILL
Treadmill turns on, It is locked in
12% incline, belt does not move, have
tried all controls. No response.
Score 1
2 Comments
This question was migrated from http://meta.ifixit.com/.
by
Pat Gross, just wondering if you ever got your treadmill fixed.
by
Add a comment
1 Answer
Chosen Solution
Pat Gross, do you have an err 3 code on the screen. Sometimes the treadmill will loose its incline signal. You may have to reset this by removing and then replacing the Safety Key. If that does not work I would think that there are the possibility of
a: mechanical failure. Remove the bottom cover and see if all the mechanisms are in place and nothing binds with the deck or
b: problems with the PCB in your control. Which would probably need to be replaced. Sorry can't be more specific with this. Good luck
Score 2
Add a comment
Add your answer
Pat Gross will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,874
