The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 Questions View all
Printer misses information on page or isn't transferring info
My printer has started to make a very loud crinkling noise and is missing part of printed field. Most recent document was only 40% visabje and not all aligned. In inspecting the rear opening, there is a very loose and damaged plastic sheet/roller cover that I see.
Can it be fixed?
Add a comment
1 Answer
Chosen Solution
@dgpagel ,Doug, 1st link is the HP support site where you may find a authorized service/support. 2nd link is a site that sells HP replacement parts and if you see the plastic sheet/roller you require for replacement click on it and a exploded parts view will come up which may aid in the installation if you want to attempt the repair. Tried to get you a free service manual, the 3rd link is to be your manual but when I downloaded it came up as 1410 model, may be the same, not sure and the 4th link wanted $5.00 for service manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www8.hp.com/us/en/store-finder/in...
http://www.printerworks.com/Top-LaserJet...
http://www.feedroller.com/store/Service%...
http://copynews.net/hp-color-laserjet-cm...
Score 1
Add a comment
Add your answer
Doug Pagel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 97
