Why won't the arm that raises and lowers the deck raise or lower?
No spring action in arm. Was cutting grass, stopped, went to raise arm and nothing. Stuck down and won't cut grass.
This could be a result of a connection somewhere that broke loose like the lift links not being connected. If you could give me a model number of the mower I could maybe find a diagram to help you find those lift link and connections.
Hey Justin, i'm having the exact same issue with my Murray. Is it possible that you can find me a diagram of the lift links or springs that connect to the arm to raise and lower the deck? Model Number 42516X92B/skynz71@yahoo.com
Having the same problem with my cub cadet 1420. Could you possibly find a diagram for it? Thanks
I have a husqvarna GTH2654 the deck won't raise or lower either.
I'm having the same issues for a Ferris zero turn 52 in deck
The front end of the deck that connects to the rod wont raise on my troy-bilt hydro
Lifting arm will not raise mower deck on XT1 w/ 46” deck?
My Deere mower
# Z997R 72" deck will not raise or lower. The height adjustment dial won't turn at all. Also, the switch on the handle that raises and lowers deck isn't working as well. Where do I start troubleshooting these two issues?
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 109
All Time: 6,794
1 Comment
my john deere model is 2320.
by jensccc
