The R52WH74 is a 52-inch rear-projection television. It was released by RCA around the year 2006.
How can I replace my speakers
I have no sound and would like to replace the speakers. I have tried adjusting all settings. Any help would be appreciated.
Add a comment
1 Answer
@bobboy5494 this would be an uncommon issue. I suggest that you connect an external audio source to the back of the TV first. See if you get any audio there. Try headphone or similar for that. If you need to check on the speakers etc. use this part from the manual
If you have no signal to your speakers I'd check the speaker connector and consider replacing the audio IC. Those are not high quality IC's and fail before the speakers do.
Add a comment
Add your answer
Cyndie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 132
