This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 Questions View all
ASUS Memo Pad 7 won't charge
I currently have an Asus Memo Pad 7 that won't charge. I've tried replacing the cord and that doesn't do anything. At one point the tablet finally came back on for about a second and showed the empty battery icon then shut off. I'm thinking that it may be the battery and that I'll need a new one. Any thoughts on how to fix it? Thanks.
Score 1
Add a comment
Most Helpful Answer
If you can, take out the battery, then plug in your charger.
I could be wrong but that will directly power the tablet, then it should come on.
If it works, then its a battery problem, if it doesn't work, it could still be a battery problem as Im not sure if that will work.
You most likely just need to buy a replacement battery for the tablet!
Score 2
Add a comment
Have you tried jumping it with a power supply?? or what volts is the battery reading when you test the leads?
If the battery is reading zero you may need to jump it then check the voltage again.
Score 1
Add a comment
Add your answer
Peyton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,017
