Released August 2003. An expensive, but high-end laptop of its time.
6 Questions View all
Power won't stay on.
When i turn the power on the power light comes on then goes right off, what could be the problem.? I took out the ram and cpu and it still does the same thing. Can you help ? Tha same thing is happening with my Dell Inspiron 6000.
Add a comment
1 Answer
Plenty of things can cause the issue, and unfortunately most of this requires trial and error.
if your device is able to boot while plugged in, and battery removed, its simply a battery problem. however, you could also have a bad charge port, that is not giving current to the device, so it is not charging. You could have a problem with a board level component as well. some devices have a failsafe, that if it does not sense a fan, it will prevent itself from booting.
these are some of the more comon reasons devices wont start.
Add a comment
Add your answer
Greg Smith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 9
All Time: 115
