Blue, red or white 11" Dell Inspiron 11-3162 released on February 16, 2016.
13 Questions View all
Why won't windows install
It says windows installation cannot proceed
Score 1
1 Comment:
Is that all it says? no error code or anything? What type of installation media are you trying to use? disk? Flash Drive? Or OS reset?
by
Add a comment
1 Answer
I will suggest you to check the BIOS settings provided below to see if you have similar settings. If not you may try these settings and then install the operating system.
  • Go to the BIOS screen by pressing F2 at the Dell logo 4-5 times.
  • Navigate to ‘Advanced Tab’ and select ‘Onboard Device Configuration’.
  • Set ‘SATA Mode’ to ‘AHCI’.
  • Navigate to ‘Boot’ tab and set ‘Secure Boot’ to ‘Enable’ and ‘Load Legacy OPROM’ to ‘Disable’.
  • Boot Mode should be set to ‘UEFI’.
  • Save the settings and Exit from the BIOS.
Once the system restarts, Go to the ‘One Time Boot Menu’ by pressing F12 at the Dell logo 6-7 times.
Select the boot device under UEFI to boot.
In case you have other problems in installing Windows update, check out those methods.
Add a comment
Add your answer
Dan groulx will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,802
