Repair information and guides for the Apple Mighty Mouse. This mouse is equipped with a laser sensor, four buttons, and a trackball.
15 Questions View all
After cleaning the ball doesn't work anymore
I have cleaned my Mighty Mouse several times following your instructions manual, but the last time I did it, the ball doesn't function anymore. Any thing I did wrong? I have used this procedure several times, and I'm sure I reassembled it correctly. Maybe the cables or the cables connectors are with problem, is it possible?
What can I try to correct this problem?
Add a comment
1 Answer
Most Helpful Answer
we find that most cases you can clean it from the outside by rolling the ball with a cleaning substance. But while doing this cleaning method does pull out some dirt that stops the ball mechanisms from rolling (there are 4 directional pins inside), the pins eventually get too clogged up to roll.
The only way of fixing it after that is to open it and clean it from the inside. it can be done, but will require cracking the lower frame off the mouse, then re-glueing it afterwards
Score 1
Add a comment
Add your answer
sergio barrozo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 174
