Panasonic Blu Ray DVD player, released in 2013, model number BD89. The BD89 has WiFi capabilities, allowing it to access streaming apps.
3 Questions View all
Blu-Ray Recorder Won't turn on with remote but will manually
I have a Panasonic DMP-BDT270 Blu-Ray 4k Player. That was not an option under devices so I said I have a BD 89 in order to get this question posted.
The remote no longer works with my Blu-Ray player. Can’t turn it on with remote. I can, however, turn it on manually… but then the remote still won’t work to allow me to move on-screen to select Episodes or scenes on the DVD. It just shows it’s on the TV but won’t play the disc inserted in it.
In summary, I can only turn the blu-ray player on and off manually. Remote won’t do anything. Also, I have changed batteries and then bought a replacement remote and that doesn’t work either.
2 Comments
I have a similar situation I have the DMP-BD75 and I accidentally factory reset it, while trying to make some adjustments to the settings. Now it will not respond to my remote. It will turn on with the remote but that is it. No other function works. I can not even turn it off with the remote. I do not have a manual, it was given to me. But I don't know how to get it back to working correctly.
Can someone please help me?
by
This happens to me regularly with my Panasonic. In my case a message pops up on screen saying something like "Remote 2". After a bit of googling I found that I need to press and hold the 2 and OK buttons for a few seconds to reintroduce the remote to the machine.
This happens every few days for me - it's really annoying - but I don't know why
by
Add a comment
Most Helpful Answer
Hi,
If a replacement remote doesn’t work either try “re-pairing” the remote to the unit.
According to the User guide:
''The remote control does not work properly:The remote control and this unit are using different codes. Turn on this unit by using the standby/on switch on this unit, and check "Remote control", which is displayed on the screen when you press a button on the remote control. Press and hold [OK] and the displayed number (" ") for more than 5 seconds”
If it doesn’t register a remote signalling, there may be a problem with the IR sensor (behind the window to the right of the Power LED - hopefully the window is not being blocked by anything in front of it)
Score 4
Add a comment
Hi mel4650
I suspect it could be due to photodiode failure on the player, thus unable to capture the signal.
If you can see the movie menu, etc, generally it should be fine, but I suggest performing additional checks to test on different kind of disk if it plays or being identified….
e.g.
CD - Pass / Fail
DVD - Pass / Fail
Blu-Ray - Pass / Fail
Score 1
3 Comments:
My Panasonic blu
by
My remote wouldn't work to my Panasonic DMP-BD89 BLU- RAY PLAYER IT WOULD SAY DVD REMOTE 2 EVERY TIME I PUSH ED A DIFFERENT BUTTON SO WHEN THIS MESSAGE POPPED UP AGAIN I PUSHED OK AND 2 HELD IT WOR 5-10 SECONDS AND BAM ITS WORKING NOW THIS IS THE ONLY THING I FOUND THAT WORKS... PRAY YOU HAVE THE SAME RESULT...
by
somtimes you have to go into the system setting and change unit setting(mixed data disc option) it only has 2 setting click on it you might need to whitch it from (mp3/jpeg/mkv) to (bdav/avchd)...
by
Add a comment
MAKE SURE THAT THE IR LIGHT FLASHS WHEN YOU PUSH A BUTTON YOU REMOTE IF I DONT LIGHT UP YOU MIGHT NEEN TO RELPACE THE IR LIGHT OR TRY ANY UNIVERSAL REMOTE YOU'LL CAN A CHEP ONE FROM WALMART FOR around 5 bucks.
Add a comment
Hi @somvetboxer3r
Here’s the user manual for the player.
Try to reset the player by following the directions as shown on p.28 under To return all settings to the factory preset. and check if that works.
Here’s a link from the service manual that may explain it better
Add a comment
Add your answer
mel4650 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 42
All Time: 4,090
