The XV40 Camry was introduced at the 2006 North American International Auto Show alongside a hybrid version and went on sale in March 2006 for the 2007 model year.
23 Questions View all
Why does my steering wheel shake/wobble while accelerating & at speed
when at speeds below 20km/h everything seems fine but once i accelerate past the 20km mark there is a very noticeable wobble in the steering wheel that gets faster the more i accelerate till it kind of mellows out. It’s a 2009 camry
Add a comment
1 Answer
Chosen Solution
# The most common reason for a car to shake is related to tires.  If the tires are out of balance then the steering wheel can shake. This shaking starts at around 50-55 miles per hour (mph).  It gets worse around 60 mph but starts to get better at high speeds.
  1. Sometimes brake rotors can be the cause of shaking.  If your steering wheel shakes while you are braking then the problem could be caused by "out of round" brake rotors.  This vibration can also be felt through your brake pedal.
  2. Another common problem that can cause shaking is when a brake caliper sticks on.  When this happens you will experience a vibration through the steering wheel starting at 45 to 50 miles per hour.  It will get very bad the faster you go, and you will also smell a burning odor when you stop.
  3. The good news is that these problems are easily avoided or corrected.
  4. The tire problem can be avoided by purchasing good quality tires and by having all of the tires carefully inspected when your car goes in for preventative maintenance service.
  5. The brake problem can be avoided by including brake caliper service when your brakes are due for maintenance.  This is particularly important for vehicles that have over 75,000 miles on them.  And, like your tires, have all of your brake pads inspected as part of a regularly scheduled preventive maintenance program.
  6. In fact, by sticking to your manufacturer’s scheduled maintenance program, you can avoid or predict these problems.  Normally, the brake and tire inspections are performed when you have an oil change.  In the case of customers who put very little mileage on their cars, this will be performed at the six month vehicle check-up.
  7. Tires wearing in a strange way or having a wheel that's out of round can both be signs of what's causing a vibration issue.  If one of the front or rear brake pads (out of four) is seen wearing more than the other, this is a sign that the brake caliper is sticking.
  8. There are many other things that can cause your car to shake.
Score 6
1 Comment:
Point 8. What website?
by
Add a comment
Add your answer
Anyanna Obisike-Oji will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 117
All Time: 28,962
