The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 Questions View all
What's wrong with the GPU?
Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.
I’ve tried a fresh install of Windows, a different drive that I know is fine, different NVIDIA drivers. So I’ve narrowed it down to the GPU.
I’ve done some runs of Furmark, and each time, when it gets to >75C it usually blue screens or freezes with blocks/stripes of green/white/purple, and if it doesn’t do that on its own, a reasonable tap on the keyboard where the GPU chip is causes it.
Is this a sign that it needs BGA reballing by a repair shop, or is it a more serious less-repairable issue?
Thanks in advance for any help :)
1 Comment
Joe McKinnon try some GPU throttling and see if it makes a difference. Root cause for this is poor airflow to keep things cool. https://rog.asus.com/forum/showthread.ph...
by
Add a comment
1 Answer
Most Helpful Answer
Yep, “Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.” thats a sign of a dying/deadGPU. If the GPU in this machine is modular and can be replaced it is a simple and relatively inexpensive fix if you have the right part. However, if the GPU is soldered to the motherboard that would require a motherboard replacement which is by far not the easiest thing to replace and it will be costly.
Score 1
Add a comment
Add your answer
Joe McKinnon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 181
