Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
U2 IC damaged, Phone won't turn on or charge. Altelnatives...?
I need some help. I got an Iphone 6S Plus that won’t turn on or charge. It was connected to a car charger and since then it’s damaged. I believe it is the U2 IC. And if I am right I’d have to replace the U2 IC right? but I have read online that the function of the u2 ic is to charge the phone when it is 1% or beyond, so if the battery of a phone would go 1% or under and it have a bad u2 ic it won’t charge but what about if the battery never goes under 15%? would I be able to charge my phone and use it if the battery doesn’t go below 15%? So if that is true I would prefer to charge the battery of my phone in another phone then put it on mine and never let it go below 15% then replacing the u2 ic which is a little complicated. Help let me know if this is true. Thanks
1 Comment
I have iPhone XS Max it’s boxpack I open this it’s not turning on screen is black it’s not charging as well can u tell me the reason
by
Add a comment
1 Answer
Chosen Solution
The iPhone 6s doesn’t even have a U2 IC. The charging circuit isn’t based on a single chip, you have several interconnected and each of them is surrounded by components supporting its functioning. When/if the phone gets overpower/overvoltage a number of things can go bad and get burned. Changing arbitrarily one specific IC without knowing what’s broken is in my opinion unprofessional and just a gamble, besides a waste of time and money.
Score 2
Add a comment
Add your answer
Alvin B will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 2,776
