Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
223 Questions View all
I bought 2 iPads. One connected using iTunes but the second one won't
I bought 2 iPads 6. One connected to iTunes, no problem. Second one won’t and I can’t turn it on to restore to factory settings as it keeps asking for iTunes. Any suggestions?
Score 1
Add a comment
1 Answer
Chosen Solution
If this is a new device, I wouldn’t waste any time trying to figure out the issue; just return it under warranty.
If you bought these units used, then it’s hard to tell as the history of the device is unknown. You could have a charge port issue, a battery issue or a logic board issue. Here are some general suggestions you could try:
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  1. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  1. You can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port.
  1. You may have a logic board issue.
Score 4
Add a comment
Add your answer
Susan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 123
