The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 Questions View all
After display repair the volume button is stuck, what's wrong?
Hey all,
I replaced the display frame on my oneplus 5, it seems to be working again but when I try to start the phone it boots in fastboot mode & keeps scrolling through the menu options. I can't select anything when it does that, though pressing volume down stops it from scrolling. When I hold down the power button for a few secs it powers down. It also does this without the backcover mounted so I don't think it's stuck.
I've already removed the motherboard once again to check out the connections under the motherboard. Could it be I reseated the connectors slightly off and that's what's causing the problem?
Thanks for your time!
Edit: When I hold down the volume down when powering on it starts up normal, everything works as it should be except the volume buttons. I can use volume down but volume up is unresponsive. Volume stays at set level, so it's not stuck always pressing volume down. I think I somehow broke it when I moved it to the new frame maybe? Still interested in your thoughts.
Score 3
Add a comment
1 Answer
I know i had a similar issue with a OnePlus 3T, the sidebuttons are just glued to the side of the frame on the OnePlus 5T aswell right?
Anyways, my buttons wouldn’t stick to the side very well so i put my own double sided tape strips there, but the strips were too thick and that made the volume up button get pressed all the time when i sealed the phone up. So i simply removed my double sided tape and used B-7000 glue instead and that fixed the problem.
1 Comment:
I too have used double sided tape and though I have had the issue that it was too tight when I put the back cover on the problem I have now also exist when the back cover isn't on.
by
Add a comment
Add your answer
Joost Seitzinger will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,061
