2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Questions View all
New Battery Is Charging & Recognized, Won't Run on Battery
Just replaced the battery in the MacBook Pro 13” with a new one from iFixIt. The battery shows up at 78% and is charging, I’m watching the mAh increase. The LED on the charger shows orange, as in charging. If I disconnect the power supply the computer won’t run on the battery alone, it must be plugged in, even though it has a charge. Any ideas?
Score 1
4 Comments
Lets get a better idea on what's happening. Install this gem of an App CoconutBattery Take a snapshot of the main window and post it here for us to see Adding images to an existing question
by
Thanks Dan, I uploaded that.
by
Well the battery does appear to be in good condition as you implied.
So that part of the circuit is working so if you now pulled the MagSafe connection he system would just shutdown on its own in a few seconds. Is that correct?
by
@danj Right, if you pull the MagSafe it powers off immediately. Battery has charged all the way up now thouhg.
by
Add a comment
1 Answer
Most Helpful Answer
Sadly, I think the switching logic which control the power source from the battery to the logic board is not working.
It’s going to take someone with deep circuit diagnosis and access to the needed schematics and replacement parts.
Score 2
Add a comment
Add your answer
Greg Dietrich will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 126
