Mid-range desktop PC made by Dell. Model number 4600.
8 Questions View all
How to Remove Hard Drive in Dell Inspiron 4600 (can't be wiped)
I need to remove the hard drive from my old Dell Inspiron 4600 but can’t wipe it as I now have now way to hook it up. I don’t want to donate it with all the info that’s in my hard drive. Please help! (I’m no techie, but I can follow instructions and use tools)
Thanks in advance for any help you can provide!
2 Comments
Hi @drasine ,
Do you mean a Dell Precision m4600 laptop or a Dell Dimension 4600 desktop computer?
I cannot find any information about a Dell Inspiron 4600.
by
If it is just removing the physical HDD and is dell dimension 4600, below the cpu casing, there are screws holding on it.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @drasine
You can consider downloading tools like Hiren
https://www.hirensbootcd.org/download/
Once you had downloaded, you can have the option to burn it into a cd or to usb thumbdrive (preferred as it is fast).
You will need another working computer to do so.
There is a tool in hiren you can use to format it.
Hard Disk Tools – Security
HDD Low Level Format Tool v4.40
For a less secure method, you can download windows 10 installer from microsoft, once download is completed, you can either burn it to a disk or usb, which usb is preferred as it is faster. boot it up and delete all partition. After which, you do a clean windows installation over.
For a secure erase, i know there is a tool which can help, but it is not cost effective for you, like wibetech hdd eraser, without a need of pc.
else if it is a concern, and there is no much option left, i would rather you remove the hdd
Score 1
Add a comment
Add your answer
Dee Serani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 371
