Water dispenser works. Ice-maker doesn't.
I have a Whirlpool Refrigerator Model WRS571CIHZ00. The water dispenser has a strong flow, but it just decided to stop making ice completely. I have disassembled the ice-maker/dispenser and checked the wires, didn’t see anything. I decided to check the continuity on the inlet valves and for some reason they all read zero. I double checked and it all reads zero. this is frustrating because I had the fridge less than 2 years. What makes it more frustrating as that I have flow to the water dispenser. Not sure what more to check. My next thought is that it could be the mother board. Someone have any thoughts?
Score 3
Add a comment
Most Helpful Answer
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
here’s a video on how to test it correctly:
https://www.repairclinic.com/RepairHelp/...
Score 3
1 Comment:
Replaced water inlet valve and pressure is good, no water to icemaker
by
Add a comment
had the same exact problem when my freezer ice machine stopped making ice. under warranty, the technician found that the water has frozen at the inlet of the ice machine. check the two water tube at the back of your fridge and follow the one that goes to the ice machine. you may use an hair dryer to melt the ice in the tube. i dont know how, but the tech manage to isolate the tube to prevent it to freeze again. no problems since 4 or 5 years now...
1 Comment:
Exactly what I found when the water dispenser was functional and the ice maker was not. The inlet to my ice maker is at the top of my fridge so pulled it up and found a chuck of ice. Pulled it out and water flowed immediately so a great sign. Unfortunately I had replaced the water inlet valve when it was not needed. Anyway I have ice now.
by
Add a comment
Add your answer
echols.kris will be eternally grateful.
Past 24 Hours: 28
Past 7 Days: 149
Past 30 Days: 725
All Time: 17,952
