The first generation Forte shares the same platform as the Hyundai Elantra (HD), though employing a torsion-beam rear suspension in place of the Elantra's multilink design.
11 Questions View all
Trying to locate & fix thCamshaft Position Sensor on 2012 Kia Forte Ex
For the life of me I can not locate where the Camshaft position sensors are. I am told there are 2. Can someone please help with a detailed description on where I can find these?
Update (11/09/2019)
Oldturkey03 is wrong
I could not find the camshaft position sensor on my 2012 Kia Forte Ex and there is nothing online. But I found it finally. Here is the camshaft position sensor. And this car only has one. Again this is for a 2012 Kia Forte Ex. You have to remove the plastic piece from the top of the engine and the tube going to the air filter to gain access to the camshaft position sensor. I am pointing to exact part on the engine. You have to remove the plug and then wiggle your way to take off the screw, pull it, and replace with the new one. I used a 10mm socket. I hope this helps someone else cause there is NOTHING online for this exact car….until now
Score 1
3 Comments
My 2012 kia optima starting and dying. Anybody who can help preciate ya?
by
Actually, this car does have two if you look directly behind that one on the opposite side of the motor you'll find the other one and by opposite side of the motor I mean close to the firewall. The one that you're pointing at in the picture is the intake camshaft position sensor the one close to the firewall is going to be the exhaust camshaft sensor. I only know this because I literally just changed this on my daughter's car two days ago. Hope this helps
by
My obd11 meter is saying it need a camshaft/crankshaft pos sensor b there's a part a and part B the auto parts guy was telling me there is 2 of them for cam n crankshaft is a different one my car will start and won't idle it will sputter n die unless I give it gas can I just replace the one sensor the oxygen sensor since I don't have a whole bunch of money
by
Add a comment
Chosen Solution
Score 2
5 Comments:
You are absolutely right. My chart was for >2014
by
Kia forte ex 2012 have 2 position sensor
On the left side from the oxygen sensor you need remove 2 pieces of metal then you can remove the sensor
This come with long connections and go to the top on the motor
by
Oxygen sensor and cam shaft sensor are not the same..I've replaced both. One is called an Oxygen sensor and the other is a camshaft position sensor
by
He's right there is only one camshaft position sensor..... If there was 2 it wouldn't be away from the camshaft. Hence the word camshaft
by
But you do have camshaft position sensor and crankshaft sensor not to far from each other,
by
Add a comment
I was told that if you have a federal emission engine, you only have 1 camshaft sensor, the California emission engine has 2, one on each side of the engine.
1 Comment:
The information I gave about this specific car is correct. The is one cam shaft and a crankshaft on the other side
by
Add a comment
Add your answer
Ray Borrego will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 169
All Time: 9,129
