Smartphone designed by Xiaomi in the Redmi Note line.
Battery changed but doesn't charge correctly
Hello everyone,
My redmi note 4 doesn't charge correctly. It stays at 2%. I thought it was the battery so I changed it but it didn't fix the problem. Do you think it comes from the charger port or from the other internals? What do you reckon I should do?
Thanks
Add a comment
1 Answer
Most Helpful Answer
Guillaume Bregeon since you already replaced the battery and it still shows the low charge it could be the connector but it could also be related to a bad PMIC . You will have to check those things out. Ultimately I’d start with a new charging board and re-evaluate after that. This shows how to replace the board. If you have the tools and the knowledge to test, you can use this schematic for reference.
Update (02/09/2020)
Start with replacing the charging board. It may just resolve your issue. If you replace it and it does not resolve the issue, then you will have to consider board level repair. Soldering a small board with some really small components requires some good tools and good skills. You would need to post some good pictures of your boards with your question Adding images to an existing question so that we can try and help with identifying components etc.
Score 1
1 Comment:
I'm not exactly sure how to find the right component for the right phone. I have a xiaomi redmi note4 Chinese edition. I'm new to solderingbut I'm tempted to give it a go.
by
Add a comment
Add your answer
Guillaume Bregeon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 292
