Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
97 Questions View all
Won't charge when is turned on
I have a costumer iPad and it won’t charge, i have changed the charging port but still the same problem, after i removed the shield and started to measure the components with multimeter I noticed some condensators are shorted to groud, but i can't identify the net because i don't have schemes for it. The shortened condensators are near the PMIC between the coils, none of them are cracked or damaged and the iPad don't heat. If someone has an idea what to do i would appreciate. Thanks in advance.
1 Comment
I forget to mention that if the battery is dead the iPad charge the battery until it powered on that it stops
by
Add a comment
1 Answer
Chosen Solution
The problem was PMIC failure.
Add a comment
Add your answer
Adrian Zymeri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
