Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
Can't Detect Bootable USB
I have a Macbook Pro late 2011. I wanted to wipe it to give to another user.
I wiped the drive in order to reinstall the OS. It had Yosemite installed before the wipe. I followed a guide which instructed me to wipe the drive and reinstall from the utilities menu. This gave me an error so I tried to reinstall using the command that installs the latest OS compatible with my device. This downloaded the Lion OS which then gave me an error of not being able to download required components.
I then created a bootable USB with Yosemite, making sure it was formatted for GUID Partition Map, and my laptop could not detect the USB when booting while holding the option key. I then tried to make a bootable USB with High Sierra and the same thing happened.
Essentially when I boot using the options key the only option I can see is to connect to internet and use Internet Recovery. Using internet recovery attempts to install the Lion OS, which then gives me the required components error previously mentioned. I’m a bit confused at this point and don’t know what else to do.
If it matters, I have been using TransMac to make these bootable USB drives because I do not have any other Mac devices to work with. I really need to be able to fix this from a windows PC at this point if possible.
Add a comment
1 Answer
I’ve never been able to get TransMac to work on my HP system ;-{
I’m not sure if its dependent on the given PC systems USB port services, as I know other have done it and others not!
Lets assume the issue is not TransMac but something with the systems USB ports.
This series has USB 2.1 USB-A ports so USB 3.x connections won’t work (that’s if its strictly a USB 3.x device).
Then there’s the power aspects of the port. Your Mac offers power for low current devices so a full sized 3.5” drive won’t work as it needs more power than what the system can offer.
If the power services have an issue then the only option is to use an external powered USB hub to supplant the MAc’s power services. You could check the systems power using a power meter like this one USB Mini Voltmeter
The last issue is the logic boards USB services has a problem.
So is there a work around?
I think you found it! You just didn’t follow through with the needed commands to enable the proper OS to install! How to reinstall macOS from macOS Recovery heres we want Option - ⌘ - R keys to get the newest OS your system can support. But why? When Apple has a certificate within the installer which expires unless Apple updates it. The older OS’s are no longer signed which is why you got the odd error. Here’s a bit more on this If you've got an old macOS install image, it will probably stop working today
There is a workaround resetting the systems date back in time!
This won’t work in your case as you would need a bootable external drive to run the installer.
Update (08/16/2020)
OK, let’s try setting up a fresh OS installer manually! You really need to do this on a Mac system.
Go to How to upgrade to macOS Sierra and jump down to Step 4, locate the Blue URL link labeled Download macOS Sierra, download the file and unpack it to get the installer. Now follow this guide: How to create a bootable macOS Sierra installer drive
USB Mini Voltmeter to test chargers and charging functionality. Image
Product
USB Mini Voltmeter
$9.99
2 Comments:
Using Command-Option-R starts the internet recovery and gets me to a point where I can attempt to reinstall Mac OS X Lion. When it tries to reinstall this version of the OS I end up with the failed to download components error. I don't think that this is the correct version for my computer so I'm not sure why internet recovery is doing this.
by
@Logan Robertson - Yes, thats expected! The Lion OS certificate has been expired! It won't work any more. You need to move up to a newer OS.
by
Add a comment
Add your answer
Logan Robertson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,765
