The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
52 Questions View all
Doesn't finger-scroll any more, but point click and drag ok
Scrolling using the finger doesn’t work anymore, but I can still point at a scrollbar and drag it around. On the same computer, another Magic Mouse doesn’t show this issue. Is it a hardware problem that can be repaired?
Thanks
Franco
Add a comment
1 Answer
Did the batteries leak? There is a connector near the battery contacts as you can see here
See if the corrosion has damaged things, which you might be able to clean off. Other than that there is very little you can fix here.
Review the teardown for more! Magic Mouse Teardown
1 Comment:
I have found out that finger scrolling works around the Apple logo, but doesn’t near the front, where the finger tip naturally stays…
In the battery compartment no leak is visible, and the batteries look ok (they are still the original Apple batteries, I’ve two sets of them). Will open the mouse and check…
Thanks
by
Add a comment
Add your answer
Franco Vaccari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 63
