Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
16 Questions View all
Any PGA478 compatible CPU's for My iMac Model?
I currently have a p7500 2.26 GHz in my iMac. I was wondering if there was any compatibles. I’m looking to upgrade the CPU to possible max performance.
I’ve looked online and it says supposedly that my CPU is socketed so I should be able too upgrade it.
I’m just not sure if Apple has locked the firmware to my specific CPU or only the CPU’s that they used in their mac models
4 Comments
Your systems specs: 20" iMac Core 2 Duo" 2.26 (Mid-2009)
The CPU in this series is a Core 2 Duo Processor P7550
by
thanks, although im not sure if i were to get a better same socket cpu would it work? im almost positive that the cpu was socketed.
by
The issue is not if the CPU is socketed or not. What are you going to install? There just isn't any TDP 25 Watt CPU's that's any better than what your system came with.
by
i just wanted to reduce lag sometimes. its usually fine though.
by
Add a comment
1 Answer
Chosen Solution
Sadly, your system is limited to Core 2 Duo CPU’s and ones that only use 25 TDP.
Score 1
1 Comment:
thanks for the heads up.
by
Add a comment
Add your answer
Stephen Whalen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 146
