The LG K20 Plus Android smartphone was released by LG Electronics in March 2017 as part of the K Series. The LG K20 Plus includes model numbers LG K20 V, LG VS501, and LG TP260.
31 Questions View all
Why won't my phone turn on after charging?
Ok, can someone help me with this...I have an LG k20 Plus phone and just three days ago, it went dead on me (as in the battery ran out.) So I went to charge it. After around an hour of letting it charge, I decided to come back and check on it. I tried turning it on, but it won’t work. So I decided to let the phone charge overnight because I thought it just wasn't charged enough or something. The next day I tried to turn it on again but it didn't work. I also tried pushing both the volume down button and the Power key in order to reboot it, but that also didn't work. I tried everything from taking the battery out and looking at youtube videos to putting it in the freezer (again, from a youtube video). Does anyone have any suggestions for this?
Score 1
Add a comment
1 Answer
Hi BelmontRose 1622 , I had read your Question about your phone current situation, i am recommending you to checking the battery first, if it corrided or any problem happened clean the pin, if it not helping you check he battery voltage and connection, is it indicating any light? while on charging, , also you can check the phone by connecting to PC, if it shows any detection of phone?, if all are not you should checking phone charging I C, i hope you got your solution
1 Comment:
Hello, my apologies for taking so long to respond. I ordered a new battery for the phone but it didn't work. The phone also doesn't indicate any light while on charging and the PC didn't recognize nor detect the device when I connected it with the USB.
by
Add a comment
Add your answer
BelmontRose1622 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 947
