Device repair guides for the 2018 Motorola Moto Z3 smartphone, model number XT1929-17.
19 Questions View all
I just changed the battery, now it won't charge.
I’m wondering if I damaged the charging circuit, failed to reconnect things properly, or if it simply needs some kind of reset.
The new battery showed 37% when I powered the phone back up. I followed the advice to discharge it completely before charging, and kind of forgot about it. I did note that the display seemed to be stuck on 37%. When I got back to the phone, it was off from being completely discharged.
I have a good charger and good cable; it works fine for other phones. The phone was charging properly before I swapped batteries. I left it on the charger overnight and it’s still at 0%
Add a comment
1 Answer
Get another battery or another charger.Be sure the battery matches the original one.Or the charger.
7 Comments:
or try the rese-and WAIT the phone is at 0 percent.
by
The replacement is a match for the old one, Motorola brand and model. The charger works fine on another phone. Did I kill the battery by discharging it completely?
by
I took the phone apart again today and connected the old battery without removing the new. Brought the phone back up and it won't charge the old battery either. I think I killed the charging circuit. Both the battery and the external charger work fine on their own.
Is there a way to replace or reset the charging circuit?
by
Send it to a tech repair station or look inside it then look up the model to see if its a match.
by
Oh the battery is a match alright
by
Show 2 more comments
Add a comment
Add your answer
Matthew Wheaton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 142
