Support and repair information for Beats Solo3 headphones.
67 Questions View all
Doesn't turn on but flashes when charging
Hi there, I've had my beats for around 2 years now, yesterday at 7pm I was using them perfectly fine with no problems at all, and then when it came around 11pm it turned on but then shut down after a few seconds, when I put it in charge it shows 3 bars and one flashing so it's definitely not dead, and occasionally it will turn on but turn off instantly, I have tried the factory reset thing so if anyone is having the same problem or has any solutions please reply
Add a comment
RayyanS04  the symptoms you describe are pretty consistent with a bad battery. Remember that even a bad battery will tell you it is charging but will not hold a charge. Replace the battery and re-evaluate.
Add a comment
hi0bui9bvivbibuboihiohi097awrestdyfugihj
IDK why I’m on this site:::::::: This site helps with nothing better just to go get it fixed than waste your time on this site.
Add a comment
Add your answer
RayyanS04 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 240
