Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
71 Questions View all
One Airpod pro bud is grainy sounding, what's wrong and can I fix it?
For a while now my right bud has been grainy (crackly), at first I thought it was just the transparency mode, but now it’s all sound coming from it. I’ve tried cleaning them, but maybe there is some wax dug in there? Maybe it’s not wax at all? Thanks for any help!
Score 1
2 Comments
If I'm not mistaken, Airpods are not repairable. Search videos as silicone(?) sealant is used to effectively render repairs impossible. There may be a replacement fee for right or left one.
by
If it’s a static sound, then I have this problem too. I’m thinking it’s mechanical, possibly a loose wire or something, because it would go away after jiggling the airpod. I’ve done that so many times now that it’s just static.
by
Add a comment
1 Answer
Chosen Solution
Hear me out, so most likely there is some stuff in your airpod that could be stuck in there but cant be removed with regular cleaning.
So if you have some blue sticky tack (the stuff that schools uses back then) just force it into the airpod's holes, then SLOWLY remove it from the hole. repeat it a few times and the noise issue should be fixed. It's an old school method I did on some Pixel Buds and some first gen airpods
Add a comment
Add your answer
mclark4386 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 694
