Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
150 Questions View all
A1932, Backlight not working, Image & caps lock ok
Macbook Air 13” A1932.
As I was using my macbook it made one “click” sound and the backlight went dark. I can see the apple logo when turning on if I shine a flashlight on it. Caps lock is lighting up and so does the keyboard. I have tried the resetting stuff with the multiple button presses, but no change. I opened the backplate to look at the logic board and did not see any obvious damage, in fact it looks new since I only used it like 4 times.
Is there anything else I can check on this model?
I have read about a backlight fuse, but I don’t know how it looks or where it is located, could somebody guide me to it?
Score 1
1 Comment
To be clear you are shining the flashlight through the lids Apple logo and can see your desktop? Or if you are in a darkened room do you see a slight glow from the system.
by
Add a comment
Most Helpful Answer
wordi pressi the backlight fuse is reference designator F8400. It is a 32V 3A fuse in a 0603 package. Location on your logicboard as shown. Measure continuity with a multimeter or your can measure for proper voltage with the board power applied.
If it is not the fuse,you will have to check deeper for the cause. Use the schematic for the backlight as provided. Do not forget to check your display connector since a lot of short circuit happen right there. Post some images of your logicboard (both sides) with your QUESTION so we can see what you see.
The image is best viewed by downloading it and using your own image viewer to zoom in.
Score 2
Add a comment
Check the display cable and see if it's loose. If it's not, replace the display.
Score 1
1 Comment:
I doubt that is the issue. The connection is quite secure unless someone has dickered with it.
by
Add a comment
Add your answer
wordi pressi will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 27
All Time: 673
