The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
124 Questions View all
boot loop apple watch series 0 sport. on both charger & off
I have a issue on a series 0 sport which is basically a series 1. I did a battery replacement from a totally dead battery. The new one gets past the snake charge screen so the battery got initialized but now it boot loops. logo 3 seconds power off. repeat every 5 min or so. force reset doesn't fix it. do you think battery isn't good? not enough voltage? no damage to the gasket touch sensor that I can see. left it on charger for 3 days so far to no help. I unplugged the battery for a day to ensure it had no power and it didn’t help. I get the boot loop on and off the charger so the battery has some power at least. It never charged more than 2.2w according to my kill a watt meter and it did this in a weird way. 7 seconds charge 5 seconds no charge. it now shows 1.3w now with same same cycling. could this new battery be bad? never seen this before.
Update (03/20/2022)
Here is what it does one charger or off the charger. Reset doesn't help but does attempt to reboot fast than the 5min cycle
Score 1
Add a comment
1 Answer
Most Helpful Answer
You really want to have a look at those two other questions with the same issue:
Apple watch stuck in a boot loop
Apple watch original boot looping on the charger
Both point to the battery as being the likely issue. The latter link points to the battery replacement guide.
Score 1
Add a comment
Add your answer
stressmaster will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 339
