A rugged waterproof portable Bluetooth speaker encased in a smooth grip-like rubber on all sides. Model # PH-BTW55 and released in 2015.
5 Questions View all
Can't control volume when connected to TV
I can't control the volume when I connect my non-Bluetooth TV to my photive speaker via RCA cable. The speaker will work fine and I can increase or lower the volume when I Bluetooth connection to my phone.
I've connected the TV to an HDMX speaker and it works fine, unfortunately, that speaker decided not to hold a charge.
Any suggestions as to why this isn't working correctly?
Add a comment
1 Answer
Most Helpful Answer
Hi @jctusa,
What is the make and model number of the TV and also the model number of the speaker if not a PH-BTW55?
Asking about the speaker model number because I'm confused regarding the speaker's line input as it uses a 3.5mm stereo audio cable connection socket and you mentioned connected by RCA cable or are you using a 3.5mm Stereo Male to 2 x RCA Male Audio Cable?
The links are examples only to show the different cable options.
For example, a PH-BT2020 model speaker the default volume is at maximum level. To control the volume level, use your device to control the volume. Note: the Play/Pause, Volume+ and Volume - buttons only work when connected via BT. When using a wired connection, the volume can only be controlled on your device.
Score 1
Add a comment
Add your answer
John Theeck Jr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 85
