Hasbro released this Furby model in 2012. Furby is intended for young children and up to young adults.
18 Questions View all
what's the energy input required to power a furby?
I have a furby boom with a battery compartment that got damaged by battery leakage. I am trying to make him functional with minimum disassembly. My plan was to disconnect the power cables from the battery connectors (the rusted metal will be removed) and use a rechargeable battery instead (lithium?). I was trying to figure out which specs I am looking at in terms of voltage and output amperage? If the batteries are in series I am looking at 6V, but if the 2 pairs of batteries are not in seires then 3V ? then I am not sure if the output on the battery matters (1.2A? 2.4A?) I can figure out how to assemble things but I just need to know I'm not gonna fry the furby haha
Edit : it requires 4AA batteries
The battery compartment
the red and grey wires on the right are connected to the metal connector in the battery compartment. It's hard to see if there are any more under the plastic shell (which is an absolute pain to disassemble and would love to avoid)
Score 1
6 Comments
Hi Sven Heizenberg,
What was the original power source? 1, 2, 3, or more AA or AAA batteries?
If we can have what it came with originally, it's easier to figure out what you'll need :)
by
It requires 4 AA batteries, but they are placed in a cross pattern in the battery compartment so I don't know if they are all 4 is series or not
by
@geirandersen oops the tag didnt work. ^ I answered above :)
by
@Sven Heizenberg,
Could you take a couple of detailed pictures and update the question with those? See this Guide by @oldturkey03 on How to add images to existing questions
by
@geirandersen would that be enough ?
by
Show 1 more comment
Add a comment
Chosen Solution
You could always try replacing the rusted terminals and solder new ones on, or you can clean them with rubbing alcohol and a q-tip, but since they are rusted, maybe use a toothbrush to scrape it off. I have seen battery compartments that look worse than that, and they are able to work again without disconnecting the power cables. There are many ways to clean battery acid. Corrosion is caused by a completely expected chemical reaction due to hydrogen gas building pressure and ultimately needing to escape from inside a battery.
  1. Apply baking soda over the entire area that's affected by corrosion. This will neutralize the battery acid. Add a small amount of water to activate the baking soda and cause a chemical reaction which will remove the corrosion. Clean and dry the area with a paper towel, and clean up any residue using a scrub sponge.
  2. Isopropyl alcohol is the best remedy for cleaning the corrosion of batteries. You should apply isopropyl alcohol on electronics because it is very safe to use. once you have applied, you need to rub it with a soft tissue or cloth.
  3. White vinegar or lemon juice: Most household batteries contain bases, so acids will neutralize their discharge.
  4. Hydrogen peroxide is an excellent cleaning agent for battery corrosion as it is an organic chemical. It is non-toxic if used correctly at the right doses. The mild oxidizer is safe to use with no toxic by-products. The chemical solution can overcome accumulated rust easily.
It is not recommended to use any chemical cleaners, such as bleach, ammonia or acetone as these can cause damage to the battery terminals. I know that 2012 furbys run on a 6 volt dc motor, therefore it would be 3 watts, 500mA for the power source. Usually, furbys only have 2 wires connecting on the battery terminals. the red and grey wires on the right are connected to separate metal connectors in the battery compartment, check the wires as they may have corrosion on them as well. Corrosion is easy to clean, but is time-consuming.
I hope this helps, Thanks!
Score 1
Add a comment
Most Helpful Answer
@Sven Heizenberg just checked on mine and it states it is a 6V 3W power supply.
Score 2
3 Comments:
That would make it 0.5A (500mA) for the power source, as a max, which sounds bang on expected.
by
I also just checked some older guides and the motor is a 6V motor. 6V 500mA battery should do the trick ! ;-)
by
thanks so much I will have a look around !
by
Add a comment
Add your answer
Sven Heizenberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 422
