A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
576 Questions View all
Can I use PS4 Original's F6202 as a donor to faulty F6202 on PS4 Slim?
I recently started repairs and bought a broken PS4 Original that had I found out has liquid damage on some parts of the board and I will now use it as a donor board for the good parts.
After that I bought a PS4 Slim and I think the F6202 fuse is blown. Can I replace it with the one of the PS4 Original? Are they the same spec?
Score 2
Add a comment
Chosen Solution
@djbaro yes, it is commonly done. The fuse is a 1A 32V in a 0402 package.
Score 3
17 Comments:
@oldturkey03 Since I posted this I looked a bit further in buying replacement parts.
I do have some follow up questions.
On Amazon I saw the necessary chips. In the description however it does say that it is only meant for the Pro and Slim version, not the original:
https://www.amazon.co.uk/2x-Small-0402-S...
Also I have seen some fuses on ali express that imply in the description f6202 on Slim is the same as f9800 on original. Could I use the f9800 instead? I'm not home so I haven't looked at the size of 9800 but according to ali express it's the same fuse:
https://a.aliexpress.com/_EIYJDVf
Any thoughts?
by
I said chips, I meant fuses
by
@djbaro that would make all of them, fuses of the same value.
by
@djbaro what length and width do you measure for that fuse.
by
@oldturkey03 I just checked, the one on PS4 original is a bit larger than the one on slim. Are you sure I can use it? (Ignore this I forgot to tag you in my previous message so I deleted it and im sending this to make sure you recieve it. I'm new to ifixitforums, so I don't know how the system works)
by
Show 12 more comments
Add a comment
0603 fuse is correct for fat http://tinyurl.com/kz4r3jyk
Add a comment
Add your answer
Baris Yilmaz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 841
