The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
6 Questions View all
Camera len don't come out
I press on the lens while it was working then the lens doesn't show up
Add a comment
Most Helpful Answer
LAETH ATHER_81 you can try and fix it first by moving the lens from side to side. It is possible that there is grime/grit/dust/sand in between the lens mechanism. Look at the lens and check it against the lens ring. See if is centered or if it is off center. If it is off-center, a little push on the side that is higher may make a difference. For some really useful tips on this, check on here. I've used a shopvac on a lens before, to assist it with extending. If nothing gets this resolved, you may have to consider replacing the lens.
Score 1
Add a comment
Try to take a flathead screwdriver and pry the lens up.
Add a comment
Add your answer
LAETH ATHER_81 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 249
