The colored buttons aren't working.
The colored buttons on my controller are not working. I've tried it with the console nothing's worked. I plan to open it up and take a look soon, but does anybody know what to expect?
Hi
Once opened up keep a eye out for corrosion and oxidation on the contacts under the membrane for the buttons
Also keep a eye out for any broken traces around that area too
Hopefully this helps
Any questions please ask
Thanks for the advice. Will fixing any of that require soldering connections? I'm sorry if I don't sound educated, I haven't worked extensively with the newer Xbox controllers.
Good question!
If there are broken traces that will need soldering but if the gold part is corroded that will just need cleaning with some isopropyl alcohol
Don’t be alarmed but the gold part as it’s meant to have a break In it,any breaks anywhere else will need fixed:-)
If you are unsure if anything let me know
@hellomacos Thank you so much. I'm working on this for a friend and it's very helpful. I'll keep in mind what you said. Have a great day.
Thanks, have a good day too,
Let me know if I can help with anything else:-)
Cheers:-)
@russellrepairs if you don't have any ipa you can use a pencil rubber to clean the contacts too.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 11
All Time: 115
