The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108 Questions View all
Moisture alert won't go away
My samsung tab A 10.1 always shows a moisture alert in the charging port and doesn't charge. The only way i can charge it is by restarting it each time. I've tried drying out the charger port but that does not fix it.
Add a comment
1 Answer
Try a toothbrush with isopropyl alcohol and clean charging port let dry then try again if that doesn't work usually the charging port needs to be replaced.
Add a comment
Add your answer
Celestial will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 98
