Manufacturer Part Number 100015685 Serial Number: G5KDCZ0670L5
16 Questions View all
The storage section in Settings won't open
The storage section in the device settings app won't open when I tap the button. It will buffer, display the settings gear icon, then return to settings page. All other sections work okay. All other apps work okay. I've reseated the card, restarted, and powered off and on several times with no effect. Any ideas?
Add a comment
1 Answer
Most Helpful Answer
Hi @remarkibal
When you say "all other sections work OK", did you clear the Settings app Cache as well? Not sure if this is what you did or not
Go to the Settings menu > find and select Apps or Application Manager > find and select the Settings app > select Storage > select Clear Cache.
Score 1
1 Comment:
Any other fixes? Having this issue as well
by
Add a comment
Add your answer
Stephen Mark will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 37
All Time: 1,250
