My Roomba isn't charging
My unit won't charge. When I connect the light on the charging unit flickers on but the unit itself doesn't display the charging signal.
Add a comment
1 Answer
Did you try another cable?
Check if the charging port is dirty, a drop of WD-40 and a needle can clean it.
The charging pin may be damaged and may need to be replaced.
Add a comment
Add your answer
Mary Ann Flannery-Stucky will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 151
