Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
Can't restore to factory default
So basically i have this old Acer computer its as aspire 5560 series and I figured I could restore it to default but it's bot working keeps telling me it's failed system restore I thought I might have some dodgy files on there due to the fact when I was younger I used to mod Xbox games extra and download dodgy Torrents so I uninstalled everything down to basic files and tried again but still no luck it keeps failing system restore how do I fix this issue also I think there is a battery problem as I can charge it for hours and it just cuts out as soon as I remove the charger so if someone could direct me to a replacement part that would be great thank you.
Add a comment
1 Answer
As for the battery problem you can take the plastic battery case apart and in side should be several 3.7 volt cartridge style batteries so if you can solder then rebuilding your old battery is the best way to go as inside the battery case there may only be one bad battery. It's also possible that the battery problem could be your rest issue as well because it tells you you need to have at least 1/2 charge to do a factory reset!
Add a comment
Add your answer
ComicalJake_TV will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 153
