Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
302 Questions View all
My truck has power but it won't crank/start
I was checking my wiring inside the my cab to adjust my alarm sensitivity but around the time I did that I tired turning on my truck. I didn't crank and when leaving it in ignition on it still had power. Most likely a loose wire was moved or something disconnected, im not that sure.
Add a comment
1 Answer
Is also possible that you ran your battery real low and it has enough power to run accessories but not enough to power the run the starter motor. Try either jump starting it or just charge the battery.
Add a comment
Add your answer
Anthony Esparza will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 32
All Time: 153
