Repair and disassembly information for HP Pavilion 15 Laptop PCs, specifically 15-eh models. The HP 15-eh is a laptop series designed for on-the-go productivity, featuring 15.6-inch displays, AMD processors, DDR4 memory, and solid-state storage. Identified by model numbers starting with 15-eh.
8 Questions View all
The screen flickers a lot and doesn't change brightness.
It also has a high pitched buzzing sound when the screen is flickering. I'm not sure what could be causing the problem. I updated drivers and it didn't go away. I thought it could be the screen itself but I'm not sure where the buzzing sound is coming from.
Add a comment
1 Answer
Well Screen flickering in Windows is usually caused by outdated display drivers. To update driver you'll need to start your PC in safe mode, uninstall your current display adapter, and then check for driver updates. Start your PC in safe mode and also check for any physical damages to hardware, software problems and bugs in specific applications.
And Also check out this video it might be helpful for you: https://www.youtube.com/watch?v=5Vl3EmyZ...
Add a comment
Add your answer
Aeiou will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 100
