Released in 2014, Dyson's AM09 is a bladeless fan-heater combo. It comes with a remote for easy control.
4 Questions View all
Fan won't turn on (main fuse blown)
Hi, my Dyson AM09 fan was knocked over and stopped working. I've taken it apart and noticed the main fuse (F1) doesn't have continuity running through it. The rest of the circuit board looks fine (see images attached). However, I'm relatively inexperienced when it comes to electronics. If I replace the fuse, is there any way to ensure it doesn't instantly blow again?
I'm also struggling to locate the fuse (46211600000) in the UK. Would any T1.6A 250v fuse be a suitable replacement/ are there any specialist shop in London where I could locate a replacement part?
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @aaronmason94673
You can order the fuse from Digikey UK
Without a schematic you could try is to use an Ohmmeter and with the power disconnected, measure between the output side of the fuse and an earth point on the board. You should not measure a short circuit i.e. 0.00 Ohms. If you do the fuse will blow.
Perhaps order 2 fuses that way if it does blow you have a replacement for after you find out why the 1st one blew. ;-)
Score 3
2 Comments:
Hi @jayeff, thanks for this. I measured between the output side of the fuse and the earth point on the board and it didn't read a short so fingers crossed.
Unfortunately Digikey UK is coming from the US with some fairly expensive shipping costs. I found this on eBay which looks comparable (https://www.ebay.co.uk/itm/283199315985 -T1.6A) and comes in a pack of three, just in case, do you think it would work? Many thanks
by
Hi @aaronmason94673
Electrically i.e. rating wise they're OK but I think that the fuses you found would be physically too small to sufficiently bridge between the solder pads for the fuse on the motherboard for a good connection.
The fuses that you found are smd package size 2410 i.e. 6.1mm x 2.6 mm x 2.6mm. Scroll down to the bottom of the Ebay page that you linked.
I'm not sure but looking at the data sheet for the fuse series (462) you posted its size is 10.5mm x 4.5mm x 4.5 mm.
You can confirm this by measuring the dimensions of the faulty fuse that is in situ to get a rough idea of the actual size.
If you find a fuse that fits etc, don't be surprised if it blows too. Perhaps not when power is first connected and the fan is turned on but maybe when some other function is then selected e.g. hi heat etc.
There's always a reason why a fuse blows. Rarely does it fail of its own accord.
by
Add a comment
Add your answer
Aaron Mason will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 218
All Time: 1,727
