It's not turn on and no lights are blink
The sanitizer has to pore the motherboard then the after effect its not turn on. What i will do. Any solution for the problem. Please helps to the problem.
Hi @pubg44748
Why did you pour sanitizer on the motherboard if this is what you did?
If the laptop has suffered water damage you need to clean it using Isopropyl Alcohol 99%+
The impurities in any liquid (except distilled water) causes corrosion and could provide circuit paths for the electricity which were not in the laptop's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your laptop and then remove the battery as soon as possible from the laptop to minimize any further damage. There is always some power on the motherboard, even if the laptop is turned off. The Power button is not a power isolating switch!
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and sanitizer. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is the maintenance and service guide for the laptop that will help.
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Thanks. I will try.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 62
