Repair guides and disassembly information for Apple's 7th generation iPad. Released September 25, 2019. Model numbers: A2197, A2200, and A2198.
122 Questions View all
doesn't turn on.
it was about a year ago when it stopped charging with its original charger, i then tried mac's charger to charge it. but it also didn't work, it was charging but very slowly and suddenly went dead since then.
i send it to local repair shop and they said probably it is motherboard issue and can't be solved. can you suggest me what to do?!
Add a comment
1 Answer
Most Helpful Answer
I know it's a fairly common issue for the CPU to die on the 7 series and it's just not worth fixing.
You could reach out to a board repair specialist to see what they have to say. If you're out of the US, I believe iPad Rehab might be able to accept the repair. If you're in the US, both iPad Rehab and VCC Board Repairs could take a look at it. I've personally taken Rehab's board repair course and I send my data recovery jobs to Jesse at VCC. Good luck!
Score 1
Add a comment
Add your answer
Omor Seebtaien will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 30
