The Kenmore Elite HE3 is a washing machine by Kenmore.
665 Questions View all
When I push power on button ...click ..that's all
Help ...top loader kenmore elite connect washing machine ...currently the lid is locked and I can't get my clothes out ....all I get is a click when I press the power on button .....I replaced the panel with the same results heard ...click
Any help will be appreciated.....
Update (11/06/23)
the model number of the washing machine is
kenmore elite 796.31522210 i got the lid unlocked /clothes out
got a new panel ... installed it and no illumination of anything
all i get ... like the old/other panel is a "click" when i push the power button ...
i believe if i can get past the "clicking" noise then i can figure out how to get
it to punch out a code or codes to tell me what the problem is ...
but can't i get more than a "click" from a push to the power on button ....
this unit is one of these NEW electronic monsters ...
holding what is wrong with it inside/keeping it a secret
any help .. thanks !!
Update (11/06/23)
ok ... tested fuse on noise filter part #A421
i removed the part and L & N tested good in and out
through the filter .... so the fuse is good .....i guess thats
why i get a click when i push the start button ....
thanks for the help/suggestion ....
any other ideas ? shawn
1 Comment:
Hi @shawnfitzg85284,
What is the model number of the washer?
by
Add a comment
1 Answer
Hi @shawnfitzg85284
Here's the service manual for the washer.
With a no power indication check if both? of the fuses in the noise filter (example only to show part) are OK. (The wiring diagram of it on p.39 of the manual shows two fuses but in images of it I can only see one?)
The location of the filter is shown as part #A241in the top cover assembly parts diagram
Hopefully this is of some help.
1 Comment:
Try the troubleshooting mode test as per p.29 then if no good see p.31 and check for the DC and AC voltages mentioned e.g. +5V and +13V & 120VAC
If none there check the mainboard unless this is what you have already replaced??
Be safety aware with the 120V AC
by
Add a comment
Add your answer
Shawn Fitzgerald will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 81
