Introduced in 2011; identified by the serial number 1d16dx.
3 Questions View all
Won't turn on, only charging led on
The computer does not turn on, only the charging LED, but when you press the power button, the charging LED turns off, after a few seconds, the charging LED comes back on. And I have already tried to do a hard reset, but it doesn't work. helped. Any advice to find out what the problem is?
Add a comment
1 Answer
Most Helpful Answer
Could just be a is defective battery.
Try taking out the main battery out and just plug in the charger.
Click here to remove battery
Does it work now?
Score 1
1 Comment:
It does not work. This had happened before, and what worked was leaving the laptop without battery for a week. I would like to know the cause or how find it, and solve it.
by
Add a comment
Add your answer
Armando Rodriguez Medina will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 58
