Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1625 Questions View all
DVD is inserting but it's giving it back
Hi, I have a problem with my macbook. The problem is that when I put CD/DVD it's get injected but the system gives it out. I tried System Diagnostic, PRAM and NVRAM. I don't know what to do about it. But the wierd question is it worked in boot order before i Install MacOS Catalina and After that I Installed Open Core Legacy Pather and it's not working. Can you help? Thank you.
Add a comment
1 Answer
Chosen Solution
Likely the optical lens is dirty, use a CD/DVD head cleaner.
Score 1
4 Comments:
Ok I bought the DVD/CD Cleaner that I put to the Mac and I will get you update if it works or not. And Thank you for Replying. :D
by
That's wierd. Beacus when I put the cd Cleaner it got stuck but that's not the problem beacus i got it back. But the problem is that the CD cleaner got accepted but my CD does the same thing.
by
@vojtechvapenik - Are you sure it’s a good disk? Clean and no scratches? And lastly a valid disk type. Try a music CD or a regular DVD movie (not blue ray)
by
Yeah I tried the disk with Windows 10 install media that is DVD RW I think And I tried a blank CD and not worked and I didn't see on both CD/DVD scratches and clean as a Fresh Water. So I orderet a Led Indicator and I'm gonna replace the disk with a dual disk so I'm gonna have 2 disk. I will try to use this as a external disk but i dont know right now. I will at least try. Thank you @anj for helping and have a good night :D
by
Add a comment
Add your answer
Vojtěch Vápeník will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 43
