A modern, mini, edition of the Nintendo Entertainment System, launched on November 2016. Also known as the Nintendo Classic Mini NES in some markets.
12 Questions View all
nes classic won't power on
i bought a faulty nes classic that i discovered won't power on. i checked for voltage with my multimeter and am getting 5 volts at the port and on every component i should be but still no power. what am i missing? it's a european model if that makes a difference
Add a comment
Most Helpful Answer
5v seems very low for a console
Score 1
5 Comments:
5 volts is all it needs since it's the mini and not the og nes
by
@techlord yea just checked the power adapter specs, maybe a power button issue
by
i checked the power button and reset button with my meter and they're functioning properly
by
@techlord any bridging pins in the hdmi port ?
by
hdmi port looks fine with no pins touching, micro usb port looks fine with no pins touching
by
Add a comment
External Power supply is 9VAC for 1.5A. After the diode rectifier bridge the supply goes to 13VDC.
3 tensions are used from this 13VDC power --> 9VDC, 12VDC and 5VDC this last one thru a LM805 egulator.
As a troubleshooting method you can connect a lab power supply tuned on 13VDC directly on the VIN leg of LM805 the regulator + GND, or on the big capacitor following the diode bridge.
If the console is still dead, the problem is elsewhere.
1 Comment:
i don't have it anymore but it wasn't the og nes, it was mini. never figured out what the fault was. when i had it and checked for voltage i was getting 5 volts everywhere i should have but still no power and the switch was ruled out since it did work
by
Add a comment
Add your answer
Cheap gamer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 295
